07-06-2010 06:28 PM - edited 03-04-2019 08:59 AM
I don't understand the concept of the set ip next-hop recursive under a route map. Any help will be very appreciated
07-06-2010 06:33 PM
Hi Luis,
This command is mostly used when you are deploying PBR.
The set ip next-hop command verifies the existence of the next hop specified, and…
if the next hop exists in the routing table, then the command policy routes the packet to the next hop.
if the next hop does not exist in the routing table, the command uses the normal routing table to forward the packet.
Have a look at this document for more info:
Reza
07-06-2010 06:45 PM
Thanks a lot.
07-06-2010 08:27 PM
hello,
i have wrote a blog for this title yesterday , seem will help you to understand.
