Help with T1 p2p issue
kevint128
We are having problem getting our point-to-point T1 connection up and running for a while now. Our service provider ran test on the circuit, but found nothing wrong. The two routers we are using are Cisco 2821 (Site A) and Cisco 2610XM (Site B). Below are the configuration and relevant information:
Site A: Cisco 2821
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface Multilink1
ip address 192.168.0.103 255.255.255.0
ip tcp header-compression iphc-format
no cdp enable
ppp multilink
ppp multilink fragment delay 10
ppp multlink interleave
ppp multilink group 1
ppp service-policy output voice_policy
ip rtp header-compression iphc-format
interface Serial0/1/0:0
bandwidth 1540
no ip address
encapsulation ppp
fair-queue
ppp multilink
Site B: Cisco 2610XM
controller T1 0/0
framing esf
linecode b8zs
ip address 192.168.0.102 255.255.255.0
no cdp enable
ppp multilink
interface Serial0/0:0
bandwidth 1540
no ip address
encapsulation ppp
fair-queue
ppp multilink
The output for 'show interface' on Serial0/1/0:0 is:
Serial0/1/0:0 is up, line protocol is down
Hardware is GT96K Serial
MTU 1500 bytes, BW 1540 Kbit, DLY 20000 usec,
reliability 128/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP REQsent, multilink Closed, loopback not set
Keepalive set (10 sec)
Last input 1d18h, output 00:00:01, output hang never
Last clearing of "show interface" counters 1w0d
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1155 kilobits/sec
2680 packets input, 61640 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1611885 input errors, 1611881 CRC, 787474 frame, 437505 overrun, 0 ignored, 1181161 abort
137393 packets output, 4104436 bytes, 0 underruns
0 output errors, 0 collisions, 13612 interface resets
14 carrier transitions
Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
The output for 'show interface' on Serial0/0:0 is:
Serial0/0:0 is up, line protocol is down
Hardware is PowerQUICC Serial
reliability 184/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Listen, multilink Closed, loopback not set
Last input never, output 00:00:28, output hang never
Last clearing of "show interface" counters 1d16h
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 8952 giants, 0 throttles
11807 input errors, 667 CRC, 4867 frame, 0 overrun, 0 ignored, 6273 abort
29180 packets output, 875400 bytes, 0 underruns
0 output errors, 0 collisions, 7819 interface resets
3 carrier transitions
13 Replies 13
pciaccio
Level 4
Level 4
You have one side running IP TCP Header compression and also IP RTP header compression and the other side is not. Try setting both sides identical to each other....
Both sides are running the tcp header compression and rtp header compression.
yes your both side configuration looks identical... will you check the debug output for the same...but debug is very resource utilization process so keep this in mind
devang
Yes, sorry missed that one.. I also see that both sides are taking excessive errirs. Is this T-1 a fully provisioned T-1 with 24 DS0's? Or should you only be using a few timeslots on it. Possibly the need to scale back the timeslots to what the T-1 may be provisioned for. You can do a show controller T1 for further details on the line...
It's a full T-1 line. I did a show controller T1 and it is showing
T1 0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20051006, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (109 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
2 Line Code Violations, 188 Path Code Violations,
5 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 4 Degraded Mins,
9 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 0 Unavail Secs
kevint128
Could all these errors caused by faulty hardware? If so, how would I go about testing what's faulty?
Yes you may have faulty hardware. Try providing a loopback to each side. If the routers see the loops good the line should come up up looped. Also I see that the LBO on one T-1 is long. How far away is the router from telco demarcation point? Plus you only showed one side of SHOW CONTROLLER T1. What does the other side look like? Another thing to try is to strip the configuration down. Do not use Multilink , just use a straight serial link with HDLC encapsulation. If the T-1 is a point to point then stripping the config will not matter for now. Just see if the line comes up. If it does then start to change the configs and make them PPP then start adding your compression and attributes to the interfaces.....Good Luck...
I just put it into loopback on each side and the line is still down and looped. The SHOW CONTROLLER T1 on the other side looks similar, it has a bunch of path code violations. AT&T hasn't been much help with this problem either.
If both sides see the loop then the show interface serial will show you looped... If they do not see the loop then you probably have an issue with the hardware on the router. Try looping the T-1 towards the carrier to the remote site and see if the loop is good. Do the same for the other side as well. Also try what I mentioned about stripping the config down...
I tried stripping the config down to bare minimum with no luck. Seems like only one of the sides is not seeing the loop and it just my luck that it's the remote side. Is there anything else I can try to narrow down what's faulty?
Thanks for all your help so far.. it's been very helpful.
At this stage in the game the only thing you can do is reverify the cabling from the telco demark to the router at the remote end. If that is OK then you probably have faulty eq. at the remote end. You will need to have it repaired or replaced...Good Luck..
csthorne
I maybe missing something, but i don't see any indication if one side of the t-1 is providing clock. i.e. clock source (line or internal) In our implementation the router at the main office the t-1 is set to internal and the remote office t-1 set to line.
Both sides are set to line as the clock source. There was nothing wrong with configuration, it was just a bad router on the other end. We ended up swapping out the router at the remote side and it's back up and running again.
