Community Member
help with temp config
Hi All,
I have a small site that will be getting a temporary internet connection until I can get the perm one there. I do not want to go through the expense of purchasing a firewall for this location, would the following config work ok if the users are only using internet and vpn? is the security sufficient?
interface FastEthernet0/0
description LAN Int
ip address <lan ip>255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0:1
ip address <ip> 255.255.255.252
ip access-group 120 in
ip access-group 130 out
no ip redirects
ip nat outside
ip route-cache flow
no fair-queue
ip classless
ip nat inside source list 2 interface Serial0/0/0:1 overload
access-list 2 remark NAT
access-list 2 permit <lan ip net> 0.0.0.255
access-list 120 deny ip <ip> 0.0.0.31 any
access-list 120 deny ip 10.0.0.0 0.255.255.255 any
access-list 120 deny ip 127.0.0.0 0.255.255.255 any
access-list 120 deny ip 172.16.0.0 0.15.255.255 any
access-list 120 deny ip 192.168.0.0 0.0.255.255 any
access-list 120 deny ip 224.0.0.0 31.255.255.255 any
access-list 120 deny tcp any any eq telnet
access-list 120 permit ip any any
access-list 130 permit ip <ip> 0.0.0.31 any
access-list 130 deny ip any any
TIA,
R
Purple
Re: help with temp config
I would actually look at the following template in order to come up with a config with a bit more security than you have got there:
http://www.cymru.com/Documents/secure-ios-template.html
It may be overkill for your network so you can remove the bits that you think are not relevant.
Pls do remember to rate posts.
Paresh
Community Member
Wow, thats quite a bit of stuff! Thanks for the template.
Community Member
The only other point I would make is if they are only using web and vpn, only permit port 80 and whatever port your VPN uses rather than the permit any any on your access-list.
163
