Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
hi ererybody
i have a problem on 4506
1 REPLY
Hall of Fame Super Silver
Re: hi ererybody
Hamid
It would be more effective if you gave postings a title that indicates what your issue is instead of "hi ererybody" which gives us very little information about whether we should even bother to read the post or not.
And saying "i have a problem" gives us nothing to work with other than the type of equipment. I do not know whether to suggest "make sure power is turned on" or to ask if there is a routing protocol. Please supply details of what your problem is so that we may give more effective suggestions.
Rick
112
