High CPU Due to Interrupts
Nidal Safadi
Hey guys;
I have a problem that tired me, and hope to find someone can help!
I have Cisco 6509-E with SUP720 which run multihomed BGP and worked very perfectly.
I'm running also: OSPF/SNMP/PBR/ACL/Distributed CEF
ISP1 bandwidth is 2.5 Gbps ( Etherchannel with 3 Interfaces) , ISP2 bandwidth is 350 Mbps.
The problem is that i have from 8am to 3pm and from 7pm to 12pm a very high CPU rate due to Interruption however ranning CEF.
All The time the CPU Rate is 87%/81%, which means that no process have a high rate
IOS Used:
s72033-advipservicesk9-mz.151-1.SY1.bin
Note: when i shutdown ISP1 the cpu go down to 7%/2%
Any show results needed i can provide it to you.
Here is some outputs can help.!
R#show switching status
Configured action on switching-bus stall : crash
Current status of switching-bus: OK
R#show interfaces switching
Port-channel1 ISP1
          Throttle count          0
        Drops         RP      29985         SP          0
  SPD Flushes       Fast      29985        SSE          0
  SPD Aggress       Fast          0
SPD Priority     Inputs         11      Drops          0
     Protocol       Path    Pkts In   Chars In   Pkts Out  Chars Out
        Other    Process        102       8058          0          0
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
           IP    Process    9593489 1350737730    9677323 1185440863
            Cache misses          0
                    Fast 1819299726 185015130948 1819196261 184996005655
               Auton/SSE 2459670049 2927525463874 3367861493 392677475638
          ARP    Process       4562     273720          5        540
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
R#show ip cef switching statistics
       Reason                          Drop       Punt  Punt2Host
RP LES No route                       28010          0        356
RP LES Packet destined for us             0     139862          0
RP LES No adjacency                    1703          0          0
RP LES Incomplete adjacency           14161          0          0
RP LES TTL expired                        0          0      99455
RP LES Routed to Null0              2851787          0      89095
RP LES Features                      138559          0      28729
RP LES Unclassified reason             6468          0          0
RP LES Neighbor resolution req         2732         19          0
RP LES Total                        3043420     139881     217635
All    Total                        3043420     139881     217635
R#show ip cef switching statistics feature
IPv4 CEF input features:
       Feature                Drop    Consume       Punt  Punt2Host Gave route
       Access List          138730          0          0      28743          0
       Policy Routing            0          0          0          0          3
Total                       138730          0          0      28743          3
IPv4 CEF output features:
       Feature                Drop    Consume       Punt  Punt2Host    New i/f
Total                            0          0          0          0          0
IPv4 CEF post-encap features:
Total                            0          0          0          0          0
IPv4 CEF for us features:
Total                            0          0          0          0          0
IPv4 CEF punt features:
Total                            0          0          0          0          0
IPv4 CEF local features:
Total                            0          0          0          0          0
5 Replies 5
Leo Laohoo
What IOS are you using?
I don't think that it's a IOS bug because i ran this switch since 3 months and the problem begin since last few days.
Nidal Safadi
I follow something from this thread:
https://supportforums.cisco.com/thread/2209968
but it didn't help or i didn't make it help me.
So please anyone can guide me ? the situation is very urgent !!!!!
One question for you then, if this is urgent why did you NOT contact Cisco TAC and raise a Case?
This is a forum.  The people who posts suggestions and recommendations are VOLUNTEERS.
Back to your issue ... Try 15.1(2)SY.
Nidal Safadi
I solved the problem, Thanks VOLUNTEERS
I found that i must make some MLS rate-limit to unicast traffic which hit my cpu at high rate without handling of CEF
Thanks Alot
