07-05-2006 05:12 AM - edited 03-03-2019 01:14 PM
Iam using cat 6500 switch ,iam a transit AS. I have 10 BGP peers in that switch.
Iam receiving the routes from these ten.
I see the cpu utilization goes upto 100
i have followed the steps given in
http://www.cisco.com/warp/public/459/highcpu-bgp.pdf
Except the replication
Still iam facing the same problem as such my cpu utilization goes high due to BGP Scanner or BGP Router Process
Can any one help regarding this.
This is my sho ver o/p
bbr02# sh ver
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 13-May-05 19:51 by ssearch
Image text-base: 0x4002100C, data-base: 0x42320000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD5, RELEASE SOFTWARE (fc3)
bbr02 uptime is 50 weeks, 4 days, 14 hours, 9 minutes
Time since bbr02 switched to active is 50 weeks, 4 days, 14 hours, 9 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System image file is "disk0:/s72033-pk9sv-mz.122-18.SXD5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C6506 (R7000) processor (revision 3.0) with 983008K/65536K bytes of memory.
Processor board ID TSC070600KH
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
1 FlexWAN controller (1 POS).
4 Ethernet/IEEE 802.3 interface(s)
38 Virtual Ethernet/IEEE 802.3 interface(s)
18 Gigabit Ethernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3 interface(s)
1 Packet over SONET network interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x10F
Ranga
07-05-2006 05:27 AM
Hello Ranga,
there could be various causes for your problem. Have a look at the document below, which might cover your issue, and which provides troubleshooting techniques:
Troubleshooting High CPU Caused by the BGP Scanner or BGP Router Process
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00801c4f48.shtml
HTH,
GNT
07-05-2006 05:39 AM
My apologies, my link is the exact same document you have already mentioned in your post...
GNT
07-05-2006 05:40 AM
I have almost tried all these trouble shooting stpes given in http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00801c4f48.shtml
excpet replication.
Iam almost receiving 526375 prefixes from all the BGP peers.
can any one help me out to resolve this issue.
Can my swicth handle this amount of prefixes.
Ranga
07-05-2006 05:34 AM
Hi Ranga,
please check your 'sh proc cpu sorted' and post your output.
Andrea
07-05-2006 05:43 AM
hi, here is the sh process cpu sorted output
bbr02#sh processes cpu sorted
CPU utilization for five seconds: 97%/4%; one minute: 65%; five minutes: 55%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
269 1352054504 10154212 133155 64.65% 7.79% 5.38% 0 BGP Scanner
267 17068362481470785672 1160 24.80% 42.62% 36.06% 0 BGP Router
138 59642644 516954 115375 2.16% 0.26% 0.17% 0 IP Background
268 5204498441482536784 351 1.08% 5.82% 5.63% 0 BGP I/O
111 4289921481921074252 223 0.92% 3.01% 2.94% 0 IP Input
35 9941800 1171664 8485 0.38% 0.04% 0.00% 0 Per-minute Jobs
281 13340 13250 1006 0.23% 0.02% 0.14% 3 SSH Process
141 10849340 48158206 225 0.15% 0.05% 0.05% 0 CEF process
thanks
Ranga
07-05-2006 05:49 AM
well, the right point to investigate is your BGP.
we need more infos, about topology and confs.
Let me know
Andrea
07-05-2006 05:59 AM
Hi andrea,
this swicth is connected to another 6500 switch.
this this swicth we have 10 BGP Sessions and 15 customer Link out of 15, 5 has BGP sessions with us.
in another cat 6506 swicth we have only 5 customer Link.
Do u require thw whole BGP config ?
One doubt is that Does My switch has the capacity to handle so much Prefixes
Ranga
07-06-2006 03:34 AM
Can any one give me a solution for this issue.
Ranga
07-06-2006 03:44 AM
Hi Ranga,
for my experience, 526375 prefixes are impressive.
Have you a IGP-BGP redistribution on your network?
Andrea
