Community Member
High CPU Utilization in Cisco 1760 Router
I am having a Router connected to Internet with Public IPs. Since last week I am receiving Alerts from my HPOV Server regarding High CPU Utilization in Cisco 1760 Router. Pls help what could be the reason. IOS is 12.3. While troubleshooting, Show Process CPU is showing that 'IP Input' is taking max. CPU
1 ACCEPTED SOLUTION
Re: High CPU Utilization in Cisco 1760 Router
The CPU load looks normal.
You are not opening any Security Hole by enabling IP CEF Cache.
Hall of Fame Super Silver
you need to verify if there a lot of packets that are process switched instead of being switched by CEF of fast switching.
Process switched packets require more CPU resources.
Try with the sh ip cef and look for the counters of packets not processed by CEF
May be your router is under attack and is receiving packets that have ip options in header that are process switched because you have public ip addresses on it
Hope to help
Giuseppe
Community Member
Pls find below the output of "Show IP Cef" from which i am not able to understand anything.
Prefix Next Hop Interface
0.0.0.0/0 attached Serial1/0
0.0.0.0/32 receive
69.165.235.104/30 attached Serial1/0
69.165.235.104/32 receive
69.165.235.106/32 receive
69.165.235.107/32 receive
69.165.235.144/28 attached FastEthernet0/0
69.165.235.144/32 receive
69.165.235.145/32 receive
69.165.235.146/32 69.165.235.146 FastEthernet0/0
69.165.235.147/32 69.165.235.147 FastEthernet0/0
69.165.235.148/32 69.165.235.148 FastEthernet0/0
69.165.235.150/32 69.165.235.146 FastEthernet0/0
69.165.235.156/32 69.165.235.146 FastEthernet0/0
69.165.235.169/32 receive
172.17.0.0/16 69.165.235.146 FastEthernet0/0
172.18.0.0/16 69.165.235.146 FastEthernet0/0
224.0.0.0/4 drop
224.0.0.0/24 receive
255.255.255.255/32 receive
Pls help.
show the configuration
Community Member
Pls find config as attachment.
try to enable CEF
interface FastEthernet0/0
ip route-cache cef
ip route-cache
interface Serial1/0
ip route-cache cef
ip route-cache
and show the output
sh int f0/0
sh int s1/0
Community Member
Cef enable as suggested. Pls find attach the Sh Int Output.
could you show the output
"sh proc cpu sort 5min" or
"sh proc cpu | e 0\.00"
Community Member
sh proc cpu | exclude 0.0
CPU utilization for five seconds: 12%/8%; one minute: 12%; five minutes: 8%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
42 653733451 757247646 863 2.12% 1.53% 1.11% 0 IP Input
108 1839 3142 585 1.14% 0.50% 0.32% 6 Virtual Exec
Hope by enabling IP CEF Cache, we are not opening any Security Hole.
Community Member
May i know in which case we should run the CEF
Hall of Fame Super Gold
In any case, and it's the default.
Community Member
Thanx Dear. Till now I have not received alert. Hope the problem is resolved now.
382
