High Packet Drop
I have 2 sites which are link together via RF. When I issue ping from site A and to site B got lots of packet drop. However, I don't see there is any error on the router ethernet interface
Re: High Packet Drop
Hi, i would try a trace route and see if you can detect where the packets are being lost. Also and extended ping might be helpful, type "ping" and then press enter and fill in the prompts, aslo check speed and duplex on both ends. HTH
esi-r1#ping
Protocol [ip]:
Target IP address: 2.222.xxx.xxxx
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 2.222.xxx.xxx
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 2.222.254.154, timeout is 2 seconds:
Packet sent with a source address of 2.222.xxx.xxx
Also, if possible give the output of the extended ping as well as show interface ethernet
Cheers,
Nikhil E.
175
