High ping loss with small payload
Hello, I have an interesting issue effecting one of my nodes. I am able to successfully ping using a 1500 byte frame but get high packet loss when using a standard 100 byte frame?  Anyone seen this? I am going to have a tech go and connect to another port to see if its an issue on the port. Here is an example:
  • #ping 172.xxx.xxx.xxx repeat 100
Sending 100, 100-byte ICMP Echos to 172.xxx.xxx.xxx,  timeout is 2 seconds:
Success rate is 95 percent (95/100), round-trip min/avg/max = 4/8/24 ms
  • #ping 172.xxx.xxx.xxx repeat 100 size 1500
Sending 100, 1500-byte ICMP Echos to 172.xxx.xxx.xxx, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 12/17/28 ms
Hall of Fame Super Silver
Re: High ping loss with small payload
Hello Brent,
did the port change provide you a solution to this issue?
Hope to help
Giuseppe
Morning Giuseppe, sorry to reply so late, no the port change did not fix the issue. We are still seeing this present on many of our Nodes.
Brent
410
