07-29-2012 07:41 AM - edited 03-04-2019 05:06 PM
Hello to the Community,
Currently we own two 7301 routers which act as LNS servers in our network,
While connecting directly to those routers, on a separate interface, and send some pings I'm getting some response times of over 200ms.
Those routers has average of 50% CPU utilization and they serve around 1500 brodband connection each.
What could be the reason for this behavior?
What else can i check on the router?
Thanks ahead,
Tal
Solved! Go to Solution.
07-29-2012 12:00 PM
Ping response time on routers are of little significace, because priority is giving to switching packets first.
So, there is nothing to worry about, and nothing to be done.
07-29-2012 12:00 PM
07-29-2012 11:13 PM
It's seems you right, i have changed the scheduler allocate value from 5000 300 to 3000 1000, which now allocate more time for process-switch processes, and the RTT is stay steady without high peaks as it was before.
Thanks.
