Community Member
HOLD DOWN AND INVALID TIMERS
HI,
Can Some one please let me know the difference between Hold Down and Invalid Timers used by the distance vector protocals.
Thanks in Advance.
Vamsi Krishna
1 ACCEPTED SOLUTION
Community Member
Re: HOLD DOWN AND INVALID TIMERS
Hi Krishna,
Holddown timer and invalid timer are different.
Holddown Timer:-- Holddown timer means a timer which starts when router receives the information about a invalid or inaccessible route from neighbor router.
Invalid Timer:-- Invalid timer means a timer which starts when a router didn,t receive an update about a route in a speceified time.
Hope it helps
Kindly rate the post if find it useful...
Mahi
HI
invalid timer means a particular router is going to mark a particular route invalid if it doesnt hear from that router for a particular amount of time usually it depends upon the protocol which u use.
hold down timer means a particular router after declaring a particular route invalid and after flash timer expires if it learns about that route agian it is going to put the that update in the state of hold for a particular amount of time before entering it in the routing table.
Mahmood
Community Member
Hi Krishna,
Hope it helps
Mahi
991
