Home Network 871
xokeman01
I know I've got old hardware but I'm learning.
I am having trouble, since I'm a newb, getting my 871 to serve up IPs to my home network.
The 871 is connected to my modem via the WAN port.
I also need to set the IP range from 192.168.1.50-150 as I have static IPs without those ranges.
Ben
Lei Tian
Hi Ben,
Config VLAN 1 with your 192.168.x.x/24 as the gateway for your LAN. Config NAT to translate 192.168.x.x to your WAN interface IP. Configure DHCP if you have host need dynamic IP. That's all you need to make it work.
HTH,
Lei Tian
Lei Tian
Hi Ben,
HTH,
Lei Tian
