01-26-2010 09:23 AM - edited 03-04-2019 07:18 AM
Please tell how to configure host based routing
my setup is like this.
ISP router , linkbalancer and fireawall are all connected to a unmanageable switch
ISP router , linkbalancer and fireawall are all having the ip address in the same subnet.
now the ISP router is forwarding traffic to firewall.
i want to configure ISP router so that it forwards traffic to linkbalancer and the linkbalancer to forward traffic to firewall.
Please help in configuring ISP router
ISP router is a cisco router.
Arulkumar
01-26-2010 09:55 AM
Hello Arulkumar,
if you are interested on sending to load balancer traffic for a subnet behind the firewall it is enough to use a static route for that subnet that specifies an IP next-hop = load balancer IP address.
The load balancer on its turn will be used as next-hop for internet or external routes by the firewall
Hope to help
Giuseppe
01-26-2010 11:55 PM
ISP router is a cisco router.Regards
Arulkumar
Arulkumar,
It just a staic routing concept in cisco router just point reverse route subnet towards the link balancer and from link balancer to firewall and for traffic towards external world firewall towards link balancer and from link balancer a default route towards ISP router.
Hope to help
Ganesh.H
01-27-2010 01:41 AM
Hi All,
Thanks for your reply.
I was trying to find the command for configuring static routes for destination in the same subnet.
I found it has to be something like this
ip route 1.1.1.1 255.255.255.255 1.1.1.2
Arulkumar
01-27-2010 01:48 AM
Hi All,
Arulkumar
ArulKumar,
Command is the same but differ with devices these command like ip route destination network net mask gateway is the genral syntax which is used to work in cisco IOS.
Differ in firewall also like this static routing commands for PIX ("route
Check ou the below link on static routing configuration command.
http://www.petri.co.il/csc_how_to_static_routes_cisco_ios.htm
Hope to help !!
If helpful do rate the vlauable post
Ganesh.H
