hot pluggin a v35 cable into serial port
Hello
Just would like to understand, is it good to plug a live serial v35 cable into a live serial port i.e with a router power on? Will it damage router hardware? or may be external csu/dsu?
If yes or no, is it the same for all other serial cables like RS232 etc.
Appreciate if Cisco can confirm that.
Regards.
Re: hot pluggin a v35 cable into serial port
hi jay
Switch off the external csu/dsu device and plug in the cable onto the serial port.
regds
Hi Prem
Thanks. Most of the projects that i handle i will be doing a lot of hotstagin and involved testing serial ports n cables. This is the reason i would like to understand whether hot pluggin of cables is allowed in serial ports?
Tx.
Jay
as mentioned earlier by Prem, you can switch off external csu/dsu and also you can shut the serial interface of router and then plug the cable to the serial interface. once done you can then switch on csu/dsu and no shut serial interface.
Jay,
Serial V.35 cables are hot pluggable.
only the serial modules are not hot pluggable
HTH, rate if it does
Narayan
thanks all for the input
Appreciate anyother input.
233
