How can doing NAT from outside (internet) to inside LAN Servers using one public IP??????
mussab-eltigani
Should I using route map ????
gcarson73
Lets say 99.3.81.66 is your public IP and ISP is on INT G0/0
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.3.81.6 443 993.81.66 443 extendable
ip nat inside source static tcp 10.3.81.61 80 99.3.81.66 80 extendable
access-list 1 permit 10.3.81.0 0.0.0.255
Int G0/0
ip nat outside
int g0/2
ip nat inside
9 Replies 9
alex_ir01
what is device are you using ?
1941 series and no firewall connected.
Are you something configure ? Please put in command line "show ip nat statistics" and show your configuration.
Vinod16
mussab
Contact your network engineer they will do the needful..
also provide him (list H323 port for VC )for opening at firewall end.
For your information no firewall used in this topology and thank you for helping.
lgdelgado
you can use the nat in tcp/udp port ej:
serv1:80
serv2:21
publicip:80 ---> serv1:80
publicip:21 ---> serv2:21
gcarson73
Int G0/0
ip nat outside
int g0/2
ip nat inside
yazeedak1988
NAT have three types:
static NAT: when you assign one public IP to one private IP.
Dynamic NAT: when you have a pool of public IPs that is mapped to a pool of private IPs.
overload NAT: when you have single public IP and a pool of private IPs, and it will use private IP user ports or process ID to built NAT table...
Use Nat overload method
mussab-eltigani
Thank you very much and for all people who tried to help me to solve this problem.....
