How Can I "Physically" Integrate MHSRP or GLBP?
mlenco
I have an edge router with a few serial, ISDN and a T1 hanging off of it. I want to put a second router online and enable MHSRP or GLBP. I can't seem to see how I could bring a second router online unless I deploy an inline switch but that would leave me a single point of failure. Any ideas?
Calin C.
Level 5
Level 5
Hi there!
Sorry but I don't understand what you want to do (maybe others don't understand too, because there are no answers here).
You have a router (R1, the existing one) and you want to add another router (let's say R2) and you connect them together via an ethernet line. Than you can do a L3 HSRP or GLBP between them.
You have below a sample config with HSRP:
R1:
interface GigabitEthernetx/y
ip address 1.1.1.2 255.255.255.248
duplex auto
speed auto
standby 1 ip 1.1.1.1
standby 1 priority 110
standby 1 preempt
R2:
ip address 1.1.1.3 255.255.255.248
duplex auto
speed auto
and use the standby ip for all the communications.
Sorry if I didn't understood what do you need.
Cheers,
Calin
Joseph W. Doherty
Ideas to avoid single point of failure, yes. For your switch, you use one that offers redundancy, e.g. chassis with multiple line card blades and reduncant components; or reduncancy via. stack of switches, e.g. 3750/3750-E series; or two switches that are interconnected. If the latter, you might have access/edge switchs with an uplink to each "core" switch, and run spanning tree. (NB: you often still have single point of failure at the edge, but that can be addressed with multiple links from hosts to different edge switches or blades on a chassis.)
