how can see more traffic tos on cisco 7606
now,on the cisco 7606 router ,only few traffic's tos,not like cisco 7507, by show ip cache verbose flow,can see all the traffic's tos.
how command can see all traffic's tos on cisco 7606.
76WA01-A1#sh ip cache verbose flow
MSFC:
IP packet size distribution (3202688 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .000 .383 .023 .091 .076 .024 .000 .006 .003 .000 .000 .000 .000 .000 .000
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
   .000 .000 .000 .318 .047 .000 .000 .000 .000 .000 .024
IP Flow Switching Cache, 278544 bytes
  8 active, 4088 inactive, 379552 added
  9844511 ager polls, 0 flow alloc failures
  Active flows timeout in 1 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33992 bytes
  8 active, 1016 inactive, 371703 added, 371703 added to flow
  0 alloc failures, 0 force free
  1 chunk, 1 chunk added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
TCP-Telnet         864      0.0       133    40      0.0      22.2      10.6
TCP-FTP              3      0.0         1   104      0.0       0.0      15.7
TCP-FTPD             3      0.0         1    44      0.0       0.0       6.2
TCP-WWW             17      0.0         2   139      0.0       0.7      15.4
TCP-SMTP             1      0.0         1    40      0.0       0.0      15.5
TCP-X                2      0.0         1    44      0.0       0.0      15.5
TCP-other        19435      0.0         1    45      0.0       2.9      14.3
UDP-NTP             29      0.0         1    76      0.0       0.0      15.5
UDP-other       210938      0.1         1   113      0.2       0.7      15.4
ICMP             22916      0.0        68  1040      0.9      13.3      13.0
IP-other        125336      0.0         9    75      0.7      34.2       7.8
Total:          379544      0.2         8   549      2.0      12.7      12.7
SrcIf          SrcIPaddress    DstIf          DstIPaddress    Pr TOS Flgs  Pkts
Port Msk AS                    Port Msk AS    NextHop              B/Pk  Active
AT1/1/0.1      80.15.20.97     Local          8.15.20.98     01 00  10       5
0000 /30 0                     0800 /30 0     0.0.0.0               100     0.1
Fa1/0/1        12.143.4.70    Null           224.0.0.10      58 C0  10       5
0000 /30 0                     0000 /0  0     0.0.0.0                60    18.5
Fa1/0/0        12.143.4.66    Null           224.0.0.10      58 C0  10      11
0000 /30 0                     0000 /0  0     0.0.0.0                60    47.0
Fa1/0/1        12.11.12.118   Null           19.251.12.1    2E 90  10       1
0000 /24 0                     0000 /0  0     0.0.0.0               160     0.0
Fa1/0/0        12.135.31.212  Local          12.143.3.200   11 00  10       1
B13C /8  0                     00A1 /32 0     0.0.0.0               102     0.0
Fa1/0/1        12.136.14.251  Local          12.143.3.200   06 00  18      21
DA02 /8  0                     0017 /32 0     0.0.0.0                40     4.2
AT1/1/0.1      8.15.20.97     Null           224.0.0.10      58 C0  10       4
0000 /30 0                     0000 /0  0     0.0.0.0                60    13.8
Fa1/0/1        12.129.115.222 Local          12.143.3.200   01 00  10       9
0000 /8  0                     0800 /32 0     0.0.0.0                84     8.0
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: how can see more traffic tos on cisco 7606
Try 'show mls ip detail'
Edison
Edison
thx. can use  show mls netflow ip qos or show mls netflow ip detail.
351
