How Erese Flash of AS5300 in Rommon mode ??????
I have put several question on forum. i have recived very positive response.
My question is How I ereas Flash of As5300.
I want upload IOS but flash space error comes in tha way.
The previous IOS size was 8.5 Mb
the newer one is of 8.2 Mb
Thanks.
Purple
Re: How Erese Flash of AS5300 in Rommon mode ??????
Do you wanna try and download a copy of a boot image for the AS5300 and see if that works ? It seems to be a very small file and so should fit in your available flash without having to erase it.
Here's the link to it:
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosresult.cgi?get_crypto=&data_from=&hardware_name=AS5300&software_name=BOOT%20IMAGE&release_name=12.0.28d&majorRel=12.0&state=:HW:SW:RL&type=General%20Deployment
Hope that helps - pls rate the post if it does.
Paresh
Thanks for the link.
but i can not get it. plz advice and suggest.
Silver
When you copy the image to flash, it would automatically ask if you want to erase flash before loading the image.
Router#copy tftp flash
Address or name of remote host []? 10.10.10.1
Source filename []? /c2600-js-mz.122-10b.bin
Destination filename [c2500-js-l.122-10b]?
Accessing tftp://10.10.10.1//c2600-js-mz.122-10b...
Erase flash: before copying? [confirm]y
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeee ...erased
Loading /c2600-js-mz.122-10b.bin from 10.10.10.1 (via Ethernet0):
[OK - 15694836/16777216 bytes]
Verifying checksum... OK (0x58D2)
Leon
* Please rate useful posts.
Thanks for the reply. i am loading the ios image with xmodem command not tftp command.
i want to ask that how i erase the flash in the rommon mode.
i have only option to upload ios with xmodem command. i there is any other possible solutiion plz advise me.
Silver
When you start xmodem copy you'll be prompted. Just load with xmodem.
Warning:
All existing data in bootflash will be lost!
Invoke this application only for disaster recovery. Do you wish to continue?
y/n [n]: y
Hi ,
I have tried but memory space error comes that's why i want erase the memory.
Hall of Fame Super Silver
You are dealing here with bootflash not regular flash. It looks like you are trying to load a regular system image into bootflash. Try loading a boot image instead and see if that works better.
Rick
Hi.
Thanks for the Ans.. How how did i know that i am copy IOS in the Boot flash.???
and what is the procedure for the normal flash ???
Thanks waiting for your response.
friends I am waiting for your response regaing the problemmmmm.. that i am facing .. How I erease the Flash Mem in Rommon Mode.
Waiting for your Response .
Thanks..
372
