Community Member
how is load-interval calculated
I have configured a multilink interface with four 2MB links in the bundle. How is the load-interval calculated for this bundled link to reflect the actual load of the combined bandwidth.
1 REPLY
Re: how is load-interval calculated
Hi Martin,
Evry individual link has a load interval of 5 mintues by default. So if you combine links in a MLPPP so have a virtual interface configured that will be a multilink interface. So to check the load on the multilink bundel you can do "show run interface mu " which will give u the combine load over the links and also the packets in/out. The load-interval will be 5 minutes bydefault.
regards,
-amit singh
128
