how many Subrate T3/E3 port card can be installed in 3745
Hi, i have a Cisco 3745 Router with 1 Subrate T3/E3 port card installed on it.
We want to add another T3/E3 card,
Q1- Can i add another card in this model?
Q2- Can we multilink bundle up two T3/E3 cards?     (current we have a single DS3 P2P connection between two office, so want to increase the bandwidth)
thank you in advance
1 ACCEPTED SOLUTION
Silver
According to this
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps4909/product_data_sheet09186a008010fba2.html
No, you can't. The 3745 only supporte one T3/E3 module.
Cheers
Silver
According to this
Cheers
Re: how many Subrate T3/E3 port card can be installed in 3745
Thank you Darren, i wish i had same searching skill + knowledge base ,one morething If i buy 3845, then can i bundle two DS3 as multilink? just like we do in T1? any idea?
Hall of Fame Super Gold
No, DS3 multilink is not supported, even if configurable.
Hi Ahmad,
Looks like from your description requirements  you are looking to increasing bandwidth?   ethernet handoffs  are becomming very popular  nowdays ,  even if you could  bandle  two DS3s you also be doubling the cost  versus using for exanple 100MB ethernet hadnoff that will probably cost you half or less than half  of  having two DS3s .
Ask your   current  circuit  provider about metro-ethernet  for increasing  bandwidth solution.
707
