how to 1ºnet to Dialer1 and 2ºsubnet to Dialer2
I have a LAN 192.168.20.0 on a GigabitEthernet 0/0. Three Dialers configured, each one with different ISP. The dialers are configured correctly. And all computers have internet with "ip route 0.0.0.0 0.0.0.0 Dialer0". If I use another Dialer the computers have internet connection too.
I create a subnet with:
interface GigabitEthernet 0/0
ip address 192.168.21.1 255.255.255.0 secondary
I have new computers on this subnet. Well. I want that this subnet use Dialer1 instead Dialer0 as default. How I can do this?
NOTE: I can not use load balance with the Dialers. I have some computers that have a direct connections that can not be interrupted.
Thanks!
Hello.
On you route-map you need to use "set interface" instead of "match interface", as it was mentioned a couple of posts before.
Also you need to deny local traffic in ACLs 101 and 102:
ip access-l ext 100
 remark do not NAT
 permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
ip access-l ext 101
 remark NAT 1st subnet
 permit ip 192.168.20.0 0.0.0.255 any
ip access-l 102
 permit ip 192.168.21.0 0.0.0.255 any
route-map PBR deny 10
 match ip address 100
route-map PBR permit 20
 match ip address 101
 set interface Di0
route-map PBR permit 30
 match ip address 102
 set interface Di1
and apply the PBR to inside interface.
6 Replies 6
Dragan Ilic
Level 4
Level 4
You can utilize Policy Based routing for this without a problem...
BR,
Dragan
HTH,
Dragan
Thanks for your response Drangan. I study this possibility, previous to ask here, I search in a lot of sites and I read http://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfpbr.html
I added:
access-list 13 permit 192.168.21.0 0.0.0.25
route-map NewSubnet permit 13
match ip address 13
match interface Dialer1
But It is not enought, I proved and the computers on 192.168.21.0 subnet not have internet connection.
What's wrong?
Best regards,
Christopher
I think you need to "set" outgoing interface..."set interface..." in route map...
BR,
Dragan
HTH,
Dragan
Hello again,
I tried different alternatives and I have no solution. I tried with:
access-list 12 permit 192.168.20.0 0.0.0.255
access-list 13 permit 192.168.21.0 0.0.0.255
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
access-list 102 permit ip 192.168.21.0 0.0.0.255 any
match interface Dialer2
route-map Datos permit 12
ip nat inside source list 12 interface Dialer0 overload
ip nat inside source list 13 interface Dialer1 overload
ip policy route-map NewSubnet
ip policy route-map Datos
ip route-map 0.0.0.0 0.0.0.0 Dialer0
ip route-map 0.0.0.0 0.0.0.0 Dialer1
I connect a pc to 192.168.21.1, this have ping to 192.168.21.1 (gateway), to 192.168.20.1 and the computers from the other network (192.168.20.x), but not have internet access. The computers from 192.168.20.x have internet access.
If I increase the permit of acces-list 12 to 192.168.0.0 0.0.255.255 and use this. NewSubnet and Datos route-map permit internet access with two net.
Any idea?
BR,
Christopher
Hello.
ip access-l ext 100
 remark do not NAT
ip access-l ext 101
ip access-l 102
 set interface Di0
 set interface Di1
Thanks!!!!
yes
