How to Achieve 4 Mbps with 2 Nos. of 2 Mbps lines
find the diagram attached to this. i hav 2 different service providers, having 2 Mbps point-to-point line. i wanted to bundle them & making it as virtually 4 Mbps line, how can i do that? it is ethernet point to point link used RAD modem for ethernet output & plugged in directly to the switch 2960. i hav 2960 on both ends, tried etherchanneling, but it didn't bundle, any help would be appreciated.
Re: How to Achieve 4 Mbps with 2 Nos. of 2 Mbps lines
Anand, Its a tough one. As we dont have the links from the same provider, you cannot really use ether-channeling. You even cannot use some other L3 mechanism to load-balance the traffic across the 2 ISP links. 2960 is a pure Layer 2 switch and it will hard to do that.
One thing that we can use is a flex link feature on the 2960's. You can set one of the ISP interface as back of the other ISP on the switch. Once the primary link goes down the other one will kick in and will start forwarding the traffic.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12225see/scg/swflink.htm
HTH,Please rate if it does.
-amit singh
Hi Amith,
but i wanted to make use of both links rather than having 1 link as primary & the other as backup. so i will drop that plan, but in your earlier postingz, u hav suggested to have to static routes point to the same destitation, so can i make use of other, by plugging on L3 switch on both the ends?
2 static routes eg.
ip route 192.168.1.0 255.255.255.0 10.1.1.1
ip route 192.168.1.0 255.255.255.0 172.16.1.1
Yes, I agree with that. We can achieve that using a layer-3 device.
Please see our earlier discussion on this post.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde906d/6#selected_message
-amit singh
By default EIGRP can do loadbalancing.
If you run EIGRP on this setup i believe you should be able to achieve this
Thanks amith.
119
