01-07-2014 03:34 AM - edited 03-04-2019 10:00 PM
Am trying to activate our broadband license on Cisco ASR 1001 with asr1001-universal.03.07.00.S.152-4.S.bin but i didn't find how to activate it and i have serached all internet for hints but no luck would please help to activate the license.
Thanks in advance
01-07-2014 03:44 AM
http://www.cisco.com/en/US/docs/ios-xml/ios/csa/configuration/xe-3s/csa-cfg-sw-activation.html
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
01-07-2014 06:18 AM
Dear Bilal
thanks for your replay but i have installed the license and when i enter the show license command i got the following status
Router#sh license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
adventerprise yes yes no no yes
advipservices yes yes no yes yes
ipbase no no no no no
avc no no no no no
broadband no no no no no
broadband_4k no no no no no
and as you can the broadband license is installed but is not enabled and also when i enter the command show license
Router#sh license
Index 1 Feature: adventerprise
Period left: 8 weeks 3 days
License Type: EvalRightToUse
License State: Active, Not in Use, EULA accepted
License Count: Non-Counted
License Priority: Low
Index 2 Feature: advipservices
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 3 Feature: ipbase
Index 4 Feature: avc
Index 5 Feature: broadband
Index 6 Feature: broadband_4k
License Count: 1/0/0 (Active/In-use/Violation)
and also it show that the license is active but not in use and i wonder how can i enable it.
Thanks again
07-27-2016 04:24 AM
Did you figure this out? I'm in exactly the same boat.
03-26-2020 08:17 AM
Ironically we have the same question now again 4 years later, have you solved this ?
We have an client that is using its box as a L2TP server with over 2000 sessions but the feature will not show "In Use"
Thanks in advance,
03-26-2020 02:42 PM
Ironically, four years later I have exactly the same problem: broadband_4k Active/Not-in-use.
Please help
