Webcast-Catalyst9k
How to adjust QoS settings?
I'm playing with QoS and trying to test my configuration. My goal is prioritization traffic on 5060 port.
I have:
1) Cisco 3750x with SVI
2) 2 PC in vlan 26 (as clients)
3) 1 PC in vlan 25 (as server)
Here is my config on 3750x:
ip access-list extended voice_acl
permit udp any any range 5060 5061
permit udp any range 5060 5061 any
class-map match-any voice_cm
match access-group name voice_acl
policy-map traffic
class voice_cm
  set dscp ef
interface Vlan25
description -= Server =-
ip address 172.25.35.1 255.255.255.0
ip helper-address 172.25.0.5
ip helper-address 172.25.10.5
service-policy input traffic
interface Vlan26
description -=Clients=-
ip address 172.25.61.1 255.255.255.0
interface GigabitEthernet1/0/11
switchport access vlan 26
switchport mode access
mls qos vlan-based
interface GigabitEthernet1/0/12
mls qos vlan-based
interface GigabitEthernet1/0/13
switchport access vlan 25
mls qos vlan-based
After configuration I tried to test prioritization. I used iperf tool to generate huge amount of traffic to make loaded network scenario.
Testing steps(see attached picture):
I - with QoS
1. On PC 3 I started iperf in server mode to listen 5001 port
2. On PC 2 I started iperf in client mode to PC 3
- steps 1 and 2 just for loading network
- then, under loaded network, I am sending/recieving packets on 5060 port.
3. On PC 3 I started iperf in server mode to listen 5060 port.
4. On PC 1 I started iperf in client mode to PC 3.
- got results(bandwidth, jitter, lost)
II - without QoS
5. Remove string service-policy input traffic on SVIs
6. Repeated steps 1-4.
I've attached the picture of the network with the test result. Unfortunatelly, there are the same results with and without QoS.
Please suggest where I am wrong in configuration and how could I adjust settings?
Thanks.
Everyone's tags (2)
116
