Webcast-Catalyst9k
How to advertise /23 on bgp
hi guys,
how can i advertise /23 on my bgp config.
like i want to advertise 100.100.100.0/23.
thanks.
jeff
1 ACCEPTED SOLUTION
Re: How to advertise /23 on bgp
the network statement has to exactly match a route in the RIB, hence your config not working since you don't have 100.100.100.0/23 in the RIB.
Try configuring the following static route instead of the two static routes you configured already:
ip route 100.100.100.0 255.255.254.0 null0
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Something like this should do the job as long as the route to that /23 is installed in the RIB on the local router:
router bgp xxx
network 100.100.100.0 mask 255.255.254.0
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
hi,
i already done that command and also put
router XXX
ip route 100.100.100.0 255.255.255.0 null 0
ip route 100.100.101.0 255.255.255.0 null 0
on my config. Failed to advertise the network. Is it possible to advertise them as /23 instead of 2x/24 ?
tnx.
jeff
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
got it. tnx a lot.
jeff
a follow up question. if i have two providers and i want to advertise /23 on the 1st one and 2x/24 on the other side. is this possible ?
yes but you have to use prefix-list or route maps
Here is a sample config
router bgp XXXX
neighbor remote-as
neighbor route-map ISP1 out
neighbor remote-as
neighbor route-map ISP2 out
ip prefix-list ISP1 seq 10 permit 10.100.100.0/24
ip prefix-list ISP2 seq 10 permit 10.100.100.0/23
route-map ISP1 permit 10
match ip address prefix-list ISP1
route-map ISP1 deny 20
route-map ISP2 permit 10
match ip address prefix-list ISP2
route-map ISP2 deny 20
HTH, rate if it does
Narayan
dear ,
Use routemap + prefix list to advertise different subnets to different isp(s)
hope this helps . rate if it does
thxn
I want to break up my subnets and advertise them with separate community values to my upstream ISP's. I?d like to change each one to /24?s so that I have more control. Currently I have a /19 & /20 which appear in the router like:
router bgp 12345
network 123.123.0.0 mask 255.255.224.0
network 234.234.32.0 mask 255.255.240.0
ip route 123.123.0.0 mask 255.255.224.0 null0
ip route 234.234.32.0 mask 255.255.240.0 null0
If I do a sho ip route 123.123.0.0 it does NOT show the null 0 route. However, if I break up these subnets to /24?s it shows a route to null 0 which drops half or all of the packets. My bgp configuration and routes become identical and it still becomes a problem! For simplicity I tried breaking the /20 into two /21?s and it didn?t work either:
Router bgp 12345
Network 234.234.32.0 mask 255.255.248.0
Network 234.234.40.0 mask 255.255.248.0
ip route 234.234.32.0 mask 255.255.248.0 null0
ip route 234.234.40.0 mask 255.255.248.0 null0
Router#sho ip route 234.234.40.1
Routing entry for 234.234.40.0/21, supernet
Known via "static", distance 1, metric 0 (connected)
Advertised by bgp 12345
Routing Descriptor Blocks:
* xx.yy.zz.6
Route metric is 0, traffic share count is 1
directly connected, via Null0
For my setup right now it does NOT show this Null 0 route when doing a ?sho ip route? statement. What am I doing wrong? Do I need to wait for bgp to reset? I tried a soft reset on one of the peers but realistically I don?t think it matters (yet) because my router isn?t recognizing the location of those routes correctly?
BTW: This is tough for me to do since I lose connectivity for those blocks when I make this change!
Help!
Goal: Balance two DS3's more effectively by using different community values.
http://cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801475b2.shtml
If you want to make sure whether the route to null0 is in the routing table, specify the mask when you do the show ip route.
Your explanation is really hard to understand. Here's a few questions for you.
- Do the /19 and /20 show up in your BGP table (show ip bgp)?
- When you configure the /24s, do they show up or not in the BGP table (show ip bgp)?
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks for the response!
Sorry for the confusion I'll post what I'm actually doing.
Problem: I cannot split up my advertised subnets. As soon as I route the subnets to null0 for BGP advertising, the router stops routing those subnets.
Goal: I'd like to change my /19 & /20 to all /24's. Ultimately I am trying balance my 2 DS3?s more effectively. I?m attempting to do this with BGP Community values (http://tinyurl.com/yxbwf5) but I need more subnets for greater control. Thus, I am trying to reduce my subnets to all /24's so I have more control with advertising. For sake of demonstration I am showing what happens when I split my /20 to a /21.
1. The /19 & /20 do show up in the bgp table before I make the split.
1a. Separate question, I'm concerned that it only lists 1 of my peers (67.96.209.62) when looking at my blocks. Doesn't it say it is advertising to 2 groups? (Stat 1)
2. You can see in Stat3 & 4 that the /21 shows up in the route table.
Basically one Stat4 shows any different results. What am I doing wrong? Do I need to reset the BGP tables? It seems unnecessary to reset the peer connections when it is a route problem on my router. When I make the change my router can no longer ping hosts on the 216.105.64.0/21 subnet.
Before:
Stat 1:
Jorge_NPE-G2#sho ip bgp 216.105.64.0
BGP routing table entry for 216.105.64.0/20, version 2166360
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to update-groups:
1 2
Local
0.0.0.0 from 0.0.0.0 (67.96.209.62)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
Stat 2:
Jorge_NPE-G2#sho ip route 216.105.64.0 255.255.240.0
Routing entry for 216.105.64.0/20, supernet
Advertised by bgp 33470
* directly connected, via Null0
Jorge_NPE-G2#sho ip route 216.105.64.0 255.255.248.0
Routing entry for 216.105.64.0/21, supernet
* 65.182.224.6
config t
router bgp 33470
network 216.105.64.0 mask 255.255.248.0
network 216.105.72.0 mask 255.255.248.0
no network 216.105.64.0 mask 255.255.240.0
exit
ip route 216.105.64.0 255.255.248.0 Null0
ip route 216.105.72.0 255.255.248.0 Null0
no ip route 216.105.64.0 255.255.240.0 Null0
AFTER:
Stat 3:
BGP routing table entry for 216.105.64.0/21, version 2163961
Flag: 0x860
1 2
Local
Stat 4:
* 65.182.224.6
router bgp 12345
Router bgp 12345
* xx.yy.zz.6
Help!
I have read through this thread, and I wonder if you could use conditional route injection in order to get your split subnets advertised. The idea is to originate your subnets 234.234.32.0/21 and 234.234.40.0/21, with the condition that a larger network that includes these subnets exists in the BGP RIB. The configuration would look like this:
router bgp 12345
network 234.234.0.0 mask 255.255.0.0
bgp inject-map ORIGINATE exist-map IF_EXIST
route-map IF_EXIST permit 10
match ip address prefix-list ROUTE
route-map ORIGINATE permit 10
set ip address prefix-list ORIGINATED_ROUTES
ip prefix-list ROUTE permit 234.234.0.0/16
ip prefix-list ORIGINATED_ROUTES permit 234.234.32.0/21
ip prefix-list ORIGINATED_ROUTES permit 234.234.40.0/21
ip route 234.234.0.0 255.255.0.0 null 0
This should get both your split subnets into the BGP RIB, and you could then advertise them both...
GNT
430
