How to apply VACL inbound and outbound
I would like to know if I can configure VACL to match inbound and outbound traffic at the same time. And where can I see examples.
Re: How to apply VACL inbound and outbound
Hello
VACLS - (specific within vlan also if no action or match statement default is to forward)
Example1 - Only allow PIng within this vlan drop everything else
ip access-List extended ICMP
Permit icmp any any
vlan acess-map Pings 10
match ip address icmp
action forward
vlan filter Pings vlan-list xx ( all)
Example2 - Deny communitcaton between two hosts in vlan 30 allow everthing else for vlan 30
access-list 101 permit host 33.0.0.3 host 33.0.0.33
access-list 101 permit host 33.0.0.33 host 33.0.0.3
vlan acess-map host2host 10
match ip address 101
action drop
vlan access-map host2host 99
vlan filter host2host vlan-list 30
SVI ACLS
int vlan 10
ip access-group 10 IN (IN >OUT)
(acls applied INbound on vlan 10 = going from a host in vlan 10)
int vlan 10
ip access-group 10 OUT  ( IN < OUT)
(acls applied OUTbound on vlan 10 = going to a host in vlan 10)
Example: denying 192.168.3.0 to access vlan 10 but allow vlan 10 to access vlab 11
vlan 10= 192.168.2.0/24
vlan 11= 192.168.3.0/24
Ip access-list extended TST
Permit tcp 192.168.3.0 0.0.0.255 any established
deny tcp 192.168.3.0 0.0.0.255 any
permit ip any any
int vlan 10
Ip access-group TST out
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Please don't forget to rate any posts that have been helpful. Thanks.
Thank you so much Pdriver, I have configured VACL and it works if packet is outbound, my doubt is if I can you use the VLAC for incoming traffic or just using ACL with access group over the SVIs?
Thank you again.
Hello
VACL are Only used WITHIN a vlan ,So if you wish to filter between a specific vlan then vacls would be applicable
Otherwise if your request is between different vlans you could use router based acls (RACL's) as shown in previous post or private vlans
Res
Paul
210
