Community Member
How to bound two t1 from the same provider on a cisco 2610
I have a cisco 2610 ios ver 12.0 with two serials.
One Wan ip from the same provider.
I would like to know how to configure my serial ports and bound them so I get 3mb.
Thanks a lot.
Re: How to bound two t1 from the same provider on a cisco 2610
You can use MLPPP, in its simplest form it should look something like this:
interface multilink 1
ip address x.x.x.x
ppp multilink
multilink-group 1
interface serial 0/0
no ip add
encapsulation ppp
ppp multilink
multilink-group 1
interface serial 0/1
no ip add
encapsulation ppp
ppp multilink
multilink-group 1
The details of the configuration depends on the layer 2 encapsulation between you and the provider.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Community Member
You would have to coordinate with your provider to have them change their encapsulation to multilink ppp. Then on your router you would have to create the multilink interface as well as change your encapsulation as well.
interface Multilink1
description To Public Internet
bandwidth 3072
ip address x.x.x.x 255.255.255.252 (usually)
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Serial0/0
bandwidth 1536
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Serial0/1
bandwidth 1536
no ip address
encapsulation ppp
ppp multilink
Please rate if this helps
222
