05-18-2012 12:41 AM - edited 03-04-2019 04:24 PM
Is possible to bypass NAT_MASQ in Cisco Router?
Here's my proposed network diagram:
thanks, thanks!
Toph Payas
05-18-2012 12:49 AM
Yes, this is possible.
You can tweak the nat rules in many ways. However, from your scheme it looks like the internet router is not on a nat outside interface.
We need to see the config in order to give more detailed hints.
regards, Leo
05-18-2012 01:16 AM
Hi Leo,
Thanks for the immediate response, what do you mean by internet router is not on a NAT outside?
Attaching another jpeg for your reference:
thanks, thanks!
Toph Payas
05-18-2012 01:37 AM
Your internet access is at 192.168.1.2, this is the same network as your def-gw (1.1)
To perform nat in the router, traffic needs to pass through it.
From a nat inside to a nat outside interface to be precise.
Leo
05-18-2012 01:45 AM
Hi Leo,
My concern:
Filtering on my firewall is not working because it only seeing the MAC Address of Def GW(192.168.1.1).
any work-around for this scenario?
thanks, thanks!
Toph Payas
05-18-2012 01:54 AM
You can still filter on ip addresses...
Or enable icmp redirects on the router. This will make the clients send their internet traffic directly to the firewall.
Leo
05-18-2012 02:00 AM
Hi Leo,
Please provide steps on how to enable ICMP redirects on Cisco Router?
thanks, thanks!
Toph L. Payas
05-18-2012 02:12 AM
Sorry but I was posting from my mobile and on that I find it cumbersome to add links or do other things than just enter text.
Now I have started a laptop and I hope the link below will answer your question:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094702.shtml#howitworks
Please rate helpful posts!
Leo
05-18-2012 06:26 PM
Hi Leo,
I'm attaching another file for your reference, .
Here's the .pkt for a more details info.
The flow will be like this:
HO_PC01 > Default Gateway: HO_Router(192.168.1.1) > HO_FIREWALL(Filtering) > Internet Cloud
Is it possible that the request from HO_PC01 > HO_FIREWALL will still be his own identity?
thanks, thanks!
Toph L. Payas
