How to check - how many ip's are accessing one particular ip
Hi Friends,
I want to check how many users(ip's) are accessing one particular ip.
Eg 10.xx.xx.xx
How many ip's are currently accessing 10.xx.xx.xx?
Tamilvanan.S
krahmani323
Level 3
Level 3
Hello Tamilvanan,
Depending on the situation, If you have access to your Cisco router I am thinking to IP accounting to enable under Router interface configuration menu (+ related options and show commands)...
http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_i1g.html#wp1091971
The ip accounting command records the number of bytes (IP header and data) and packets  switched through the system on a source and destination IP address  basis. Only transit IP traffic is measured and only on an outbound  basis; traffic generated by the router access server or terminating in  this device is not included in the accounting statistics. Traffic coming  from a remote site and transiting through a router is also recorded.
Regards.
Karim
Leo Laohoo
You could scan the IP address range using AngryIP or check the DHCP lease.
