how to check loop break in PRI
we have one PRI from service provider which is directly terminated in the router.
How we will check the loop given by the service provider on our router?
Is there any specific command for this...?
PS:PRI is terminated ib E1 controller
Silver
Re: how to check loop break in PRI
This link may help. But it indicate the loopback test for the router and not the line. I believe you have to ask the PTT to do it loopback test t their side.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a008010059a.shtml
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a754b.shtml
Hope this helps.
Hi Parvinder,
To check the loop from the service provider on router you need to run debug for isdn.Use command debug isdn q921.Refer to following link for troubleshooting tips on T1 PRI.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801509d7.shtml
I hope this helps.Kindly rate this post.
cheers
Sachin
217
