09-13-2006 11:37 AM - edited 03-03-2019 01:59 PM
I inherited the router from my previous admin. I have two questions
* I see ip nat outside on my fast ethernet interface(inside network) and ip nat inside on my serial interface (isp network)
My question is where do I find the range for these addresses. i.e. what is my inside nat address range and where is my outside nat address range
2. My ISP has given two class c subnet address to us. Where would I see them in the router configuration.
Chandru
Solved! Go to Solution.
09-13-2006 12:21 PM
The first line means you have a pool with only one public IP (66.250.38.8) for every internal device.
The second line means you are translating your inside network by using ACL 102 and also performing PAT (overload) by using the public IP from above.
09-13-2006 11:58 AM
Chandru,
You have it backwards, the inside nat should be in the fastethernet interface while the outside nat should be in the serial.
The range should be in the ip nat source statement if there is any. If there isn't any, you should contact the ISP for your allowed range.
As for the class C IP assignment, it's allocated by the ISP headend towards your network. Your router won't have that information. You can use the block as you wish (for servers, NAT, DMZ, etc).
09-13-2006 12:07 PM
I found this in my running configuration, so what exactly does this mean
ip nat pool test 66.250.38.8 66.250.38.8 prefix-length 24
ip nat inside source list 102 pool test overload
09-13-2006 12:21 PM
09-13-2006 12:30 PM
Thanks Edision, your answers provided solution for my question
There is no way other than calling ISP for the address allocated.
Chandru
