09-21-2017 03:56 AM - edited 03-05-2019 09:09 AM
besides fast convergence time and least number of topology change
which command and in which content can compare performance after tune OSPF network
Solved! Go to Solution.
09-21-2017 08:41 AM
which OSPF parameters have you changed, and what does your topology look like ? Below is a list of all the OSPF debug commands:
Router#debug ip ospf ?
adj OSPF adjacency events
database-timer OSPF database timer
events OSPF events
flood OSPF flooding
hello OSPF hello events
lsa-generation OSPF lsa generation
mpls OSPF MPLS
nsf OSPF non-stop forwarding events
packet OSPF packets
retransmission OSPF retransmission events
spf OSPF spf
tree OSPF database tree
09-21-2017 06:50 AM
Try to transfer files using iPerf. Would be better if you had transfered something before for comparison.
09-21-2017 08:14 AM
If in packettracer or gns3,
how to compare ?
09-21-2017 08:18 AM
GNS3 you can integrate with VMs. Packetracert is more limited.
09-21-2017 08:41 AM
events OSPF events
flood OSPF flooding
mpls OSPF MPLS
packet OSPF packets
spf OSPF spf
09-21-2017 02:53 PM
Ispf level 1 and timer throttle spf and hello timer
is there more parameters that can improve ospf?
moreover, I see timer throttle spf use topology change time just more than it little
where can find this change time?
i know spanning tree topology change
but where is ospf topology change time for timer throttle spf?
09-21-2017 04:36 PM
09-21-2017 03:04 PM
If there is one path from one area and another area and near no topology change
can we adjust hello timer to maximum time?
09-21-2017 04:39 PM
09-21-2017 04:44 PM
What do it mean to catch the loss?
how to find this loss?
why do no topology change have loss?
09-22-2017 03:16 AM
For "catch the loss" I have in mind the loss of a link. However it could also be the addition of link, but adding links often doesn't have the impact to traffic that losing a link does.
Finding the link loss (or addition) would be by monitoring the route table and/or OSPF database.
A topology change would cause a loss (or addition), but neither might not impact traffic.
09-21-2017 04:48 PM
How to simulate this loss or reproduce this loss situation?
09-22-2017 03:18 AM
Manually remove or add a network to the topology.
09-22-2017 03:22 AM - edited 09-22-2017 03:23 AM
If there is no addition or remove link in bank network
where is the smallest number of topology change come from?
09-22-2017 03:44 AM - edited 09-22-2017 03:45 AM
If there is no change to topology, you shouldn't be receiving topology changes.
