how to configure 2 bundl's over E1
hi i need to know how can i configure 2 bundle's , i have 2 interface mulrilink over E1 and i get the error
Dec 1 17:10:41.471: %LINK-3-UPDOWN: Interface Multilink2, changed state to down
Dec 1 17:10:41.471: Se3/2:0 MLP: Request add link to bundle
Dec 1 17:10:41.471: Se3/2:0 MLP: Adding link to bundle
Dec 1 17:10:41.471: Se3/2:0 MLP: Bundle R1 in different multilink group
Dec 1 17:10:41.471: Se3/2:0 MLP: Link not added to bundle
Dec 1 17:10:42.467: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/2:0, changed state to down^Z
regards
  • WAN Routing and Switching
Silver
Re: how to configure 2 bundl's over E1
I doubt if you can add the same interface to 2 Different Multilink. What exactly are you looking for ? Maybe Multilink Frame Relay may solve your issue if you are looking to Seperate traffic logically.
no i have 2 couple interfaces and i need 1 multilink each .
Silver
Ok that is possible to do. There is no problem in that. Can you set pp chap hostname on all the links in the bundle and shut and no shut the bundle once and see if it comes up
yep i do it and steel the same :(
let me remind u that i need two multilink over 2 serial from 1 router to another one ...
when i do shut to one interface it's work but both interface multilink it doesnt work.
regards
Silver
Can you paste from both ends ? It may be helpful.
96
