04-04-2006 06:05 AM - edited 03-03-2019 12:17 PM
I am pazzled how the switch connect to the router. Please assist.
04-04-2006 06:25 AM
you can refer this link in getting the required functionalities configured in your box..
regds
04-04-2006 08:29 AM
are you trying to use the 1800 router as a core switch to define vlans? it sounds like that is what you are talking about. please describe in greater detail what you're looking to do...
04-04-2006 09:34 AM
I am trying to establish a connection between the router and a built in switch. Do I need a physical connectin? I ssumed the connectin is intergrated. Thank you.
04-04-2006 11:12 AM
I got it! I am up and running. Thank you very much!
