How to configure Multilink PPP over Frame-relay?
rkendrick_2
We currently have 2 frame T1s on the host-end (Mackie) and 2 frame T1s on the remote-end (Yorkville). I am wondering how we can use MLPPP to aggregate these 2 links together to look like 1 virtual Multilink interface. I saw some info on this searching on Cisco but it talked about Policy routing and policy maps were a pre-requisite(???) It also had some virtual-templates that confused me.
Below is the config:
version 12.3
service password-encryption
hostname Yorkville
ip cef
no ip dhcp use vrf connected
no ip domain lookup
no ip ips deny-action ips-interface
no ftp-server write-enable
no crypto isakmp enable
interface GigabitEthernet0/0
ip address 10.10.10.1 255.255.255.0
ip accounting output-packets
duplex full
speed 100
interface Serial0/0/0
no ip address
encapsulation frame-relay
no fair-queue
interface Serial0/0/0.1 point-to-point
description Link#1 to Mackie
ip address 17.1.150.26 255.255.255.252
frame-relay interface-dlci 600
interface Serial0/0/2
no ip address
no fair-queue
interface Serial0/0/2.1 point-to-point
description Link#2 to Mackie
ip address 17.1.150.50 255.255.255.252
frame-relay interface-dlci 602
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.2
ip route 10.2.200.0 255.255.255.0 17.1.150.25
ip route 10.2.200.0 255.255.255.0 17.1.150.49
no ip http server
no ip http secure-server
access-list 10 permit any log
access-list 15 permit any log
end
What will I need to achieve MLPPP? I accomplished this easy on some Internet P-2-P's but the DLCI portions and 'encap frame-relay' parts have me worried with this scenario.
Thanx...
7 Replies 7
wochanda
Level 4
Level 4
At this time using MLPPP to bind multiple frame-relay DLCI's isn't a supported configuration. Instead we encourage our customers to use MFR, a protocol that allows you to share a DLCI among multiple T1 lines. This protocol is negotiated between your router, and your providers frame-relay switch, so you need to ask them to configure it as well. Here is more information:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087cbf.html
Hi Reginald,
THis is easy. You need to create virtual templates and map these to the interfaces you want to include in the Multilink. I have implemented this and works out to be fine
and Policy maps are not a prerequisite for this.
Here is a sample config..only relevant portions have been attached
interface Multilink1
keepalive 1
ppp multilink
ppp multilink group 1
interface Serial0/0/0:0
bandwidth 1536
no ip address
keepalive 1
frame-relay lmi-type ansi
interface Serial0/0/0:0.1 point-to-point
keepalive 1
frame-relay interface-dlci 600 ppp Virtual-Template1
interface Serial0/0/2:0
bandwidth 1536
no ip address
keepalive 1
interface Serial0/0/2:0.1 point-to-point
keepalive 1
frame-relay interface-dlci 600 ppp Virtual-Template2
interface Virtual-Template1
bandwidth 1536
no ip address
keepalive 1
ppp multilink
interface Virtual-Template2
bandwidth 1536
no ip address
keepalive 1
ppp multilink
Check this link for more details
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804a4097.html
HTH, rate if it does
Narayan
Hi Narayan,
I need to configure MLPoFR and prior finding your sample config I found the same link that you attach. Related to this link, in order to configure MLPoFR it's necessary to configure Frame Relay Traffic Shaping, and in your sample config is not configured. Do you have test this configuration without Frame Relay Traffic Shaping and it works?
I had tried configuring MLPoFR without Traffiic shaping and I get this message on the router:
FR-3-MLPOFR_ERROR: MLPoFR not configured properly on Link Virtual-Access4 Bundle Multilink1 :Frame Relay traffic shaping must be enabled
Besides, I loss some pings to the other side and the speed that I get is 6M downstream 2M upstream and it should be 6M / 6M
My config:
ip address 10.100.100.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink fragment disable
interface Serial0/2/0
no ip address
encapsulation frame-relay IETF
interface Serial0/2/0.1 point-to-point
bandwidth 2000
frame-relay interface-dlci 100 ppp Virtual-Template1
interface Serial0/2/1
no ip address
interface Serial0/2/1.1 point-to-point
bandwidth 2000
interface Serial0/3/0
no ip address
interface Serial0/3/0.1 point-to-point
bandwidth 2000
no ip address
load-interval 30
ppp multilink
I have implemented this without traffic shaping and it works out fine although you keep getting the above syslog.
Also you need to mention the Bandwidth under the virtual template interface for the multilink to interpret it correctly.
Use keepalive 1 as an option as it will reduce the timeouts you encounter when one link from the bundle fluctuates.
Narayan
Ok, I have configured with the bandwidth on the virtual template and now the bandwidth of the interface multilink is correct.
Thanks a lot for your help.
Since I'm replacing 2 serial sub-interfaces, should I have 2 Virtual Templates like your example shows or only 1 Virtual Template with bandwidth at 3072?
It is preferable to have 2 virtual templates with each associated to one sub interface
Narayan
