How to connect 6 fan wires
I want to connect six fans 12v in the connector of cat 6500 that has five pairs
::::: of 12 v.Somebody to help me? Thank you
1 REPLY
Re: How to connect 6 fan wires
this does not sound like a supported solution. From an electrical perspective you will either have half or twice the resistance connected and this can lead to some unwanted behaviour. The outcome might be a damaged circiutry on the Cat6500. I would strongly recommend not to try this.
Hope this helps! Please rate all posts.
Regards, Martin
80
