Community Member
how to disable isdn slot
  Hello All,
Below is the error we are getting on our 3845 router and after diagnosis we came to know that there is some problem with ISDNBRI card fixing and is loose but we dont want to touch router as it is online . So is there any CLI command so that we can disable slot 1 on our router.
%OIR-3-SEATED: Insert/removal failed for slot 1, check card seating
%OIR-6-REMCARD: Card removed from slot 1, interfaces disabled
Hemant
1 REPLY
Hall of Fame Super Gold
Re: how to disable isdn slot
There are no commands for that.
317
