How to disable PVST
How to disable the default mode PVST in cisco switches.
Whether cisco switches support the CST?
1 REPLY
Re: How to disable PVST
Hi Balakrishnan,
If you want to implement only one STP instance for all vlans, you can use Multiple Spanning Tree (MST).
Here's link that will help you how to configure MST:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swmstp.html#wp1043798
Cheers:
Istvan
1749
