Community Member
How to do remote backup connection
I have a primary site with private connection via MPLS and then I have a cable modem connection. Right now we use 2801 router for primary connection and pix 501 for backup connection via VPN. The fail over is not automatic. Anything I can do?
1 REPLY
Community Member
Re: How to do remote backup connection
i think you can usw HSRP for the local fail over. You should use the MPLS VPN connection for primary usage (do you use dynamic routing protocols in your MPLS VPN?) and also a dynamic routing protocol between the 2801 and the pix. (i hop the pix support it ... i have'nt use the pix at this moment).
100
