Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
How to enable a command?
how do I enable a priv exec command that is disabled by default?
As an example: how do I enable "show DMVPN". It appears from below that it needs to be "enabled". I am using a variety of IOS post 12.4 Thanks
show dmvpn
To display Dynamic Multipoint VPN (DMVPN) specific session information, use the show dmvpn command in privileged EXEC mode.
show dmvpn [peer [nbma | tunnel {ip-address}] | [network {ip-address} {mask}]] [vrf {vrf-name}] [interface {tunnel number}] [detail] [static] [debug-condition]
Command Default
This command is not enabled.
Command Modes
Privileged EXEC
Command History
Release Modification
12.4(9)T
This command was introduced.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: How to enable a command?
Jeff
Thank you for posting the additional information. It helps to make clear what the problem is. It does make clear that the command is not available on your router. And the reason is clear based on this posting of additional information. In your original post you included this information:
Command History
12.4(9)T
Note that the code was introduced in the T train of code not the mainline. In this post you gave us part of show version:
R1#sh ver
Cisco IOS Software, 3700 Software (C3745-ADVIPSERVICESK9-M), Version 12.4(18), RELEASE SOFTWARE (fc1)
and this indicates that you are running 12.4(18) which is main line code. To get this command you will have to change the image that you are running and run something from the 12.4T train of code.
Rick
hi
can you revert back whether you are logging in using the user id/password with limited privileges or limited access ???
If you are logging in with such an user id you are restricted to the commands which you are allowed to execute.
You wont get the output of the command if you are executing from a privilege level which is not configured or permitted to do so...
regds
Connecting via console with enable password and with local account / priv 15 access level.
From my perspective - I have no reason to believe it is a limited priv level issue. The command show DMVPN doesn't even come up as an available command.
I agree - if I was using an account with limited access - it makes sense not to be able to execute the command.
Jeff
Perhaps you can clarify a few things for us:
- are you using on line help and saying the command is not available because it does not show up or are you attempting to enter the command and getting a response of invalid input? (I have seen many instances where on line help did not show a command which executed just fine if you enter the command)?
- is DMVPN supported in the version and feature set that you are running? Perhaps you can post the output of show version so that we can see what version and what feature set you are running?
- Is DMVPN configured and running on this router? I am not clear from the excerpt from the documentation quoted in the original post what it takes to enable the command but believe that I have seen situations before where some command was not enabled until the feature that it related to was configured.
Rick
Thank you for the questions
Show DMVPN does not show up as an available command. I rechecked the feature set and it supports DMVPN phase 1. I have DMVPN configured on R1 as Hub and R2, R3 as Spokes.
Example:
R1#sh dmvpn
% Invalid input detected at '^' marker.
R1#sh d?
dampening data-corruption debugging derived-config
dhcp diag dial-peer dialer
dialplan diffserv dnsix dot1x
dspfarm dss dtp dxi
R1#sh ver
R1#sh crypto sess
Crypto session current status
Interface: Tunnel0
Session status: UP-ACTIVE
Peer: 60.60.2.1 port 500
IKE SA: local 60.60.1.1/500 remote 60.60.2.1/500 Active
IPSEC FLOW: permit 47 host 60.60.1.1 host 60.60.2.1
Active SAs: 2, origin: crypto map
Interface: Tunnel0
Peer: 60.60.3.1 port 500
IKE SA: local 60.60.1.1/500 remote 60.60.3.1/500 Active
IPSEC FLOW: permit 47 host 60.60.1.1 host 60.60.3.1
Active SAs: 4, origin: crypto map
R1#sh ip nhrp
172.16.31.2/32 via 172.16.31.2, Tunnel0 created 00:10:15, expire 00:05:17
Type: dynamic, Flags: authoritative unique registered
NBMA address: 60.60.2.1
172.16.31.3/32 via 172.16.31.3, Tunnel0 created 00:10:15, expire 00:06:50
NBMA address: 60.60.3.1
R1#sh crypto isakmp sa
dst src state conn-id slot status
60.60.1.1 60.60.3.1 QM_IDLE 2 0 ACTIVE
60.60.1.1 60.60.2.1 QM_IDLE 1 0 ACTIVE
Hub t0
R1#sh run int t0
Building configuration...
Current configuration : 419 bytes
interface Tunnel0
description DMVPN Connection to the Internet
bandwidth 100000
ip address 172.16.31.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 48202
ip nhrp holdtime 450
ip tcp adjust-mss 1360
delay 1000
tunnel source FastEthernet3/0
tunnel mode gre multipoint
tunnel key 2332
tunnel protection ipsec profile dmvpn
end
Jeff
Command History
12.4(9)T
R1#sh ver
Rick
Thank you for your help. I'll go back to the drawing board on understanding the differences in code and features.
Jeff
There are many different code trains in IOS and I agree that sometimes it is difficult to understand them. In very general terms the main line code is the versions of code with no letters at the end of the name. Other code trains are identified by some combination of letters at the end of the release identifier. Within a version of main line code in the major releases (12.1, 12.2, 12.3, and 12.4) Cisco attempts to keep the features supported pretty much the same and different minor releases (12.4(9) or 12.4(18) have mostly bug fixes and preformance enhancements. The new features get introduced in the T train (sometimes referred to as the Technology train - or maybe as the Testing train). So features that were inroduced in 12.3T become the base line of features supported in 12.4. And the show dmvpn that was introduced in 12.4T will become a main line feature in whatever major release follows 12.4.
Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read responses which successfully resolved the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
1825
