how to enable an SPA-4XT3/E3
sdns_swrmc_lan
I'm having difficulty enable an SPA-4XT3/E3 and need some guidance.  I've checked the online references and didn't see anyting related to the issue.
Here is some output.
6500B#sh hw-module subslot 5/2 fpd
                             H/W   Field Programmable   Current   Min. Required
Slot Card Type               Ver.  Device: "ID-Name"    Version      Version
5/2 SPA-4XT3/E3 <DISABLED>  1.1   1-ROMMON               2.12        2.12
                                   2-I/O FPGA             1.1         0.24    *
                                   3-E3 FPGA              1.4         1.4
                                   4-T3 FPGA              1.4         1.4
NOTES:
       - FPD images that are required to be upgraded are indicated with a '*'
         character in the "Minimal Required Version" field.
       - The following FPD image package file is required for the upgrade:
         "c6500-fpd-pkg.122-33.SXI5.pkg"
I didn't try enabling the card, but get the message its not present.
6500B(config)#card type t3 5 2
Card not present
6500B#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 17:57 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
6500B uptime is 18 hours, 43 minutes
Uptime for this control processor is 18 hours, 41 minutes
Time since 6500B switched to active is 18 hours, 41 minutes
System returned to ROM by  power cycle at 07:58:17 PST Tue Mar 27 2012 (SP by power on)
System restarted at 14:43:29 PST Tue Dec 17 2013
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-vz.122-33.SXI5.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6506-E (R7000) processor (revision 1.1) with 516096K/8192K bytes of memory.
Processor board ID SAL1030W769
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 SIP-200 controller .
10 Virtual Ethernet interfaces
98 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
Jon Marshall
Paul
I may be completely wrong as i have never used these cards in a 6500 so just ignore me if you know this isn't a problem but isn't the output saying you need an image upgrade ie.
NOTES:
Jon
I thought that as well, but we running that version listed.
6500B#sh ver
Paul
I believe the SPA card does not use the main IOS image, it needs it's own and that is why you are getting the message about upgrading. Basically when you upgrade your IOS there is an automatic FPD upgrade for any SIP/SPA cards but you need to have the FPD image on your switch. It could be that the card was only added after you had that IOS on the switch.
Have a look at this doc which explains all about FPDs and how to upgrade  -
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/6500series/76fpd.html
Again, i admit i may well be wrong, as i have never used these type of cards in a 6500 but have a read of the doc and see what you think.
Jon
Thank you, I'll read it.
