How to Load-balance Dual-homed BGP!?
Hey everybody, this is my first post... hopefully I'm doing this properly. I have a dual-homed ISP architecture that I would like to take from active/standby to load-balanced. I'm BGP peering with both ISPs and redistributing all the routes into my OSPF core. Is there a simple way to load-balance the two ISP links in this architecture? Maybe there's a way to carry the AS path into OSPF and calculate that into the metric? Please help!
  • WAN Routing and Switching
Silver
Re: How to Load-balance Dual-homed BGP!?
You can load-sharing it by simply to implement equal cost load-sharing (if it is same ISP).
Or try to load-sharing it by selected routes for specific path.
or just based on the routes learned from both ISP and the traffic flow to shortest path (if it is two ISPs).
If it is same ISP but dual links, check will it able to enable Multilink PPP to make two interfaces as logically grouped as a single link.
Hope this helps.
Can you please let me know whether you are dual homed to 2 different ISPs or a sigle ISP
What are the prefixes you are receiving from your ISP BGP peers?
Narayan
you also might want to have a look at the following document, which has numerous sample configurations for BGP load balancing scenarios:
Load Sharing with BGP in Single and Multihomed Environments: Sample Configurations
http://www.cisco.com/warp/public/459/40.html
GNT
Hello, I followed this documentation from cisco site. But me did not work. follows the topology and configuration attached below.
RouterA
interface FastEthernet0/0
ip address 10.10.10.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 20.20.20.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet2/0
ip address 1.0.0.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet2/1
ip address 2.0.0.1 255.0.0.0
duplex auto
speed auto
router bgp 300
no synchronization
no bgp log-neighbor-changes
network 1.0.0.0
network 2.0.0.0
neighbor 10.10.10.10 remote-as 100
neighbor 10.10.10.10 route-map UPDATES-1 in
neighbor 20.20.20.20 remote-as 200
neighbor 20.20.20.20 route-map UPDATES-2 in
no auto-summary
access-list 1 permit 0.0.0.0
access-list 2 deny   0.0.0.0
access-list 2 permit any
route-map UPDATES-2 permit 10
match ip address 1
route-map UPDATES-2 permit 20
match ip address 2
set weight 100
route-map UPDATES-1 permit 10
match ip address 1
set weight 100
route-map UPDATES-1 permit 20
match ip address 2
Router SP-A
ip address 10.10.10.10 255.0.0.0
duplex auto
speed auto
router bgp 100
no synchronization
neighbor 10.10.10.1 remote-as 300
neighbor 10.10.10.1 default-originate
neighbor 10.10.10.1 soft-reconfiguration inbound
no auto-summary
Router SP-B
ip address 20.20.20.20 255.0.0.0
duplex auto
speed auto
router bgp 200
no synchronization
neighbor 20.20.20.1 remote-as 300
neighbor 20.20.20.1 default-originate
neighbor 20.20.20.1 soft-reconfiguration inbound
no auto-summary
In the example of the site said to use an access-list to match traffic from 128.0.0.0 1.0.0.0 until I changed the access-list to get the default (0.0.0.0) and enter the command "
neighbor ip default-originate" even so not working. Does anyone have any idea where I'm wrong?
Regards.
Blue
I hate to do this to you, but why dont you give this a read and see if it helps you.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml#conf4
Victor
hello lamav this was precisely what documentation of the Cisco I read. If you look at the settings are identical to the example.
Regards.
3261
