Community Member
How to Load Balance Etherchannel, when things are static?
Folks:
This is a simple config, I have a VMWare ESX3.5 server that accesses an iSCSI storage system across a Cisco 3650 switch, On the ESX3.5 server side, there are 3 NIC's dedicated to the VMSwitch that the VMKernal accesses the iSCSI Luns. The iSCSI lun's are presented from a device with teamed NIC's that present 1 “virtual” NIC to the Cisco switch. I would like the ESX3.5 server to use each of the 3 NIC's available.
Now the rub is both the src/dest MAC's are always the same, as well as the source/dest IP addresses. Meaning the VMKernal IP address 192.168.4.14/MAC abcd.abcd.abcd.0001 will always talk to iSCSI storage server at 192.168.4.10/MAC abcd.abcd.abcd.0002. From my observations and “test etherchannel load-balance” there is only 1 NIC used to transfer data no matter what load-balance hash I use (the below is when I test XOR/IP hash.
How can I get the load to be round-robin to the three available NIC's.
Here's the appropriate Cisco config portion:
port-channel load-balance src-dst-ip
interface Port-channel1
description iSCSI ESX Access
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet0/30
description ESX iSCSI NIC
duplex full
channel-group 1 mode on
spanning-tree portfast
interface GigabitEthernet0/31
duplex full
interface GigabitEthernet0/32
duplex full
S1#$hannel load-balance interface p01 ip 192.168.4.10 192.168.4.14
Would select Gi0/31 of Po1
S1#$hannel load-balance interface p01 ip 192.168.4.14 192.168.4.10
Hall of Fame Super Silver
Re: How to Load Balance Etherchannel, when things are static?
on some switching platforms you can use the L4 ports to perform the exor
see the following:
Switch(config)#port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
dst-mixed-ip-port Dst IP Addr and TCP/UDP Port
dst-port Dst TCP/UDP Port
mpls Load Balancing for MPLS packets
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-dst-mixed-ip-port Src XOR Dst IP Addr and TCP/UDP Port
src-dst-port Src XOR Dst TCP/UDP Port
src-ip Src IP Addr
src-mac Src Mac Addr
src-mixed-ip-port Src IP Addr and TCP/UDP Port
src-port Src TCP/UDP Port
not all options are avaible on all platforms try to see if your switch supports src-dst-port
hope to help
Giuseppe
Community Member
Giuseppe:
Thanks for responding! The Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2 IOS/load-balance options for the 3650 doesn't have "port" hash options, just these:
dst-ip Dst IP Addr
src-ip Src IP Addr
I'm thinking that I need to provide more variability to the source or destination. I'm looking to see if I can bind additional IP's to the iSCSI NAS appliance and serve some lun's from unique IP addresses.
I was afraid the C3560 doesn't support the port options.
If you can make your traffic more variable you an achieve some load sharing effect
Best Regards
Giuseppe
Community Member
Guiseppe:
I agree, I'll see if I can do this by adding some Nic's/IP's to the NAS device.
Mark M.
604
