08-30-2013 01:42 AM - edited 03-04-2019 08:54 PM
I search a way to log routing changes in the RIB or in the bgp table, when a route was added or removed
Is there a way to achieve this on a cisco ISR 2901 Version 15.3(2)T ?
thanks for any tips
08-30-2013 07:03 AM
Hello Abdessamad ,
I don’t remember any command use to logs BGP route addition/deletion but you can use "bgp log-neighbor-changes" command to see log messages generated when a BGP neighbor resets, comes up, or goes down. If you want to see route addition or deletion you have to debug command like "debug ip route". Use debugs carefully in live networks
Ashish Shirkar
08-30-2013 07:52 AM
thanks ashish for the contribution
I already know theses commands
thanks
09-02-2013 06:25 AM
if anyone can give me any tips for this
thanks
