how to reduce routing table entries...
i have a customer connected to my PE router .he is connected through ebgp.
he needs to have his routing table size reduced.
could anyone let me know how to achieve this ..i guess static routes will will be one solution...
1 REPLY
VIP Purple
Re: how to reduce routing table entries...
there are various ways to achieve that: either you could configure aggregate addresses on your end, or you could filter what is goinf out at your end, or what is coming in at the customer PE end, suing distribute and prefix lists. Check these links for configuration examples:
Configuring BGP Route Filtering by Neighbor
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcprt2/1cfbgp.htm#wp1001443
Configuring BGP Filtering Using Prefix Lists
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcprt2/1cfbgp.htm#wp1001470
HTH,
GP
249
