how to reduce total output drops
we have connection between 6509 switch interface and 3725 access device. however on output drops are increasing 6509 interface, any ideas how can i make to zero. below are sh int output for both device.
6509-CORE-1-1#sh int gi3/2
GigabitEthernet3/2 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0015.2bb1.87d9 (bia 0015.2bb1.87d9)
Description: ::ge3/2::oper::3725-ACCESS-1-1::fa0/0::100M
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
reliability 255/255, txload 17/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input 00:00:33, output 00:00:02, output hang never
Last clearing of "show interface" counters 00:36:44
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 4417
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6000 bits/sec, 5 packets/sec
5 minute output rate 7013000 bits/sec, 1561 packets/sec
12989 packets input, 2170281 bytes, 0 no buffer
Received 993 broadcasts (993 multicasts)
0 watchdog, 0 multicast, 0 pause input
3523848 packets output, 1963109904 bytes, 0 underruns
3725-ACCESS-1-1#sh int fa0/0
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0011.9267.d7c0 (bia 0011.9267.d7c0)
Description: ::fa0/0::oper::6509-CORE-1-1::ge3/2::100M
Internet address is 10.200.0.5/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w5d
5 minute input rate 10000 bits/sec, 9 packets/sec
5 minute output rate 9000 bits/sec, 7 packets/sec
160141872 packets input, 3554767197 bytes
Received 4856018 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
154246689 packets output, 3477017281 bytes, 0 underruns
1 ACCEPTED SOLUTION
Re: how to reduce total output drops
I don't think there is much you can do about it. You have averaged 7 Mbps over the last 5 minutes, and it would be a pretty fair bet that from time to time you are going over the 100 Mbps on peaks. At that point the interface is congested, and will drop packets as soon as the output queue is full.
If the drops are disrupting any applications, you can manage the congestion by giving priority to the sensitive applications. That opens the QoS can of worms.
If you need a quick and easy fix, it is to upgrade the link to Gbit. That would at least defer the problem, but it might give you another problem downstream.
I know the drops don't look good, but if they are not upsetting any applications then they do no harm. You could simply let them happen, and keep an eye on it. Otherwise, manage them.
Kevin Dorrell
Luxembourg
These drops must be due to the hardware queuing but doesnt matter compared to the output rate on interface. It would have been bothering when there were errors on interface or CRC.
i can see no CRC errors currently but still output drops are increasing, kindly suggest
hi guys any ideas on this ? what should i check to troubleshoot
Kevin Dorrell
Luxembourg
458
