How to remove DDNS entry
How would I remove this TZO DDNS entry in the attached file?  Thanks
1 ACCEPTED SOLUTION
hi roger,
put a 'no' to negate the said command. give it a try.
Router(config)#no ip ddns update method tzo
hi roger,
Thanks!   that did the trick!
Best Regards,
Roger
288
