how to setup a router to see more than one subnet on 1 interface
Can anyone help me out with setting up a router interface with more than one subnet. We have 4 buildings all on different subnets. We want all of the subnets to be able to talk and see each other. Each building has fiber to it and we are upgrading from 4 routers to 1, we bought a 2821 router and can't figure it out.
Hall of Fame Super Bronze
Re: how to setup a router to see more than one subnet on 1 inter
What type of switch each building has? You should be able to accomplish inter-vlan routing with Layer3 switches. It's more efficient than having a router perform that function.
If you have a 3560, 3750, 4500 or 6500 switch in your network - you have the ability to configure those devices as routers.
__
Edison.
We have HP Procurve switches.
If you are planning to use sub-interfaces, here is sample config;
interface FastEthernet0/0.1
description building-1
encapsulation dot1Q 1 native
ip address 1.1.1.1 255.255.255.0
no snmp trap link-status
interface FastEthernet0/0.2
description building-2
encapsulation dot1Q 2
ip address 2.2.2.2 255.255.255.0
interface FastEthernet0/0.3
description building-3
encapsulation dot1Q 3
ip address 3.3.3.3 255.255.255.0
Reza
will i still need to create a vlan?
yes, you do.
Example:
Switch in building-1 VLAN 1
Switch in building-2 VLAN 2
Switch in building-3 VLAN 3
etc
and my router will know which vlan to go over by the ip correct?
do i need to setup an ip just for the interface of just for the sub interface?
you need 1 subnet per sub-interface
Do i need to make all of the native?
You are only allow to have one native Vlan in dot1q trunking. The native vlan is defined as the 'untagged vlan'. You need to match the untagged vlan from your procurve switch with the one configured at the router. The router will know what vlan the packet is coming from based on the tag on the packet header.
Keep in mind, on this design - you will have a bottleneck at the router LAN interface and your inter-vlan throughput will be limited to the speed of the LAN interface on this router.
I really recommend getting some Layer3 switches, they don't need to be Cisco brand. HP also sells Layer3 switching equipment.
HTH,
__
Edison.
327
