06-07-2017 10:57 PM - edited 03-05-2019 08:40 AM
I have a Cisco 890 Router. But I lost the setup CD/DVD to configure my Cisco 890. Can somebody tell me
how I can access the webinterface or setup from this router. Or can I somewhere download the software?
Thx
Solved! Go to Solution.
06-17-2017 12:42 PM
On that picture you are the privileged exec mode, now you can configure the router executing configure terminal
06-08-2017 03:21 AM
Please check this link, basically it is the configuration used on the devices, now if you are going to use the local credentials created on the device you need to configure:
ip http authentication local
The Access-list can be optional.
http://www.cisco.com/c/en/us/td/docs/ios/12_2/configfun/configuration/guide/ffun_c/fcf005.html
Also I was reading you need at least this image installed on your device:
15.2(4)M2
or
15.3(1)T
Hope it is useful
06-09-2017 10:53 AM
I can access the interface via IP but it asks for username and password. These I don't know anymore. I already reset the router. Is there
any dafault username and password?
Kind Regards
Wesley
06-09-2017 11:11 AM
try:
Username: Admin
Password: none (that means empty)
or
Username: cisco
Password: cisco
or
Username: Cisco
Password: Cisco
06-09-2017 11:37 AM
doesn't work :(
I get this:
The server 192.168.1.100 is asking for your user name and password. The server reports that it is from level_15 or view_access
06-09-2017 11:40 AM
try 'username1' for both username and password...
06-09-2017 11:47 AM
no luck. Strange. Reset and still nothing
Type: cisco892w-agn-p-k9
06-09-2017 11:51 AM
try:
username1
password1
This is a one time username and password and needs to be changed after logging in...
06-09-2017 12:06 PM
also nothing. I dont know what could be the problem here with this router....
06-09-2017 12:16 PM
How do you reset the router ? With the reset button at the back ?
Unplug the router, push and hold the reset button while you plug the power cord back in. Continue holding the reset button for up to 30 seconds and let the router boot as normal.
06-09-2017 12:18 PM
have you tried:
admin
admin
06-09-2017 12:07 PM
Please check this link:
http://www.cisco.com/c/en/us/td/docs/routers/access/800/hardware/installation/guide/800HIG/initalconfig.html
If you have access via CLI, you can configure:
Example:
username Cisco Privi 15 password Cisco
enable secret Cisco
06-09-2017 01:11 PM
Now it is resetted correctly. Now I have IP 10.10.10.1
Gonna try now the basic username and password
06-09-2017 01:14 PM
Perfect, please keep us posted.
06-10-2017 01:22 AM
the following I get when login in to the router is:
Cisco CP Express requires at least Internet Explorer 5.5, Netscape Navigator 7.1,
or Firefox 1.0.2.
Your browser does not seem meet these requirements. (Netscape version 7.0)
You can continue, but proper functioning is not guaranteed.
Using: Explorer 11, also have Firefox and Edge. Chrome also not working.
When clicking OK nothing happens
Kind Regards
