How to show ip bgp
Hi guys,
Can i show routes filtered by local preference or weight. Example is show ip bgp routes with local preference of 200.
Tnx
Hall of Fame Super Silver
Re: How to show ip bgp
Hello Jefferson,
you can filter the sh ip bgp output with a route-map
sh ip bgp route-map loc-pref-200
where the route-map has been defiend as:
match local-preference 200
For weight I don't know it is not a match option in a route-map
Hope to help
Giuseppe
I mean on the sh ip bgp regexp command when checking routes.
TNx
Hello Jefferson,
as far as I know the regexp will look at the BGP AS path attribute and local-preference and weight are different BGP attributes
see:
#sh ip bgp regexp ?
LINE A regular-expression to match BGP AS paths. Use "ctrl-v ?" to enter "?"
So I think you cannot find loc-pref or weight inside AS path
Hope to help
Giuseppe
hi there,
It's difficult to match exatly your requirement.Still u can filter out by using sh ip bgp | include or exclude or using reg expression after include.
The Weight atribute is local to a router, can be applied only on incoming updates, and is never propagated.
Therefore, you will not be able to match based on it!
if you used route maps, yes you could see them. use the show route-map command. you will see the associated attribute used in your filtering.
You CANNOT *match* based on Weight, you can only *set* it!
170
